Factory Electrical System - Up to Upgrades?
Hello All - I am trying to plan out my truck upgrades and I'm focusing on the electrical system. I have tried to calculate the electrical load. Now I just need advice as to whether the stock factory system will be able to handle it.
Upgrades:
Audio Amplifiers = 110 - 120 amps
Driving Lights = 10 amps (two lamps at 55W each divided by 13.8volts)
Fog Lights = 10 amps
Backup Lights = 10 amps
So a total of roughly 140 - 150 amps in addition to the regular draw.
Is the factory charging and supply system up to the job? Keep in mind that I will not be using all of these at the same time.
Any recommendations for upgrades?
I plan on doing replacing the wiring from the alternator and battery to a large size (big 3). I also considered upgrading to a higher amperage alternator, but I have read that it operates on the vehicle computer and getting an aftermarket alt to work isn't possible.
Upgrades:
110 amps continuous out of an amplifier? is that what it is fused at? or did you do the wattage/ voltage to get that?
i had a 600 watt amp in my jeep, and 4- 100 watt lights, 2 55 watt lights, and it did fine...
i'd assume you will be fine also
