Daytime running light intermittent
I am experiencing issues with the daytime running lights and headlights on my 1996 Ford F150. The daytime running lights are intermittent and "flash" on and off during operation. I am also experiencing issues with the low beams. When the low beams are on there are periods when the high beam indicator will illuminate dimly on the dash and the headlights will flicker. The headlights will sometimes not turn off if the ignition is turned off prior to the lights being turned off. The daytime running lights now flash during start up and then go off (I assume they are staying off??). I hope someone has an idea what might be causing this.
Thanks,
Fred
Thanks,
Fred
