Help! No Right Rear Turn Signal
I installed a Recon mini led tailgate light bar which plugs into the trailer pig tail. After I installed the light and pulged it up, my right turn signal stop working. I knew something was wrong because when I switch it to the right, it was blinking toooo fast in the front and not at all in the back. It is not the bulb socket. I replaced it. Still nothing. I have already pulled out what little hair that I have on my head and chin. Help please
Do you have a right rear brake light function or parking lamp ?
You make no note if you removed the Recon led tailgate bar when you were testing, did you return thing to the way they were when the right turn signal worked ?
