This problems got me puzzled. Extra 2 amps going somewhere...
So I was using my 2005 F-150 as a daily commuter until recently when I bought a Maxima. So now the truck sits for 3-7 days at a time without being driven. First week it wasn't driven, the battery was completely dead. I charged it up and it did the same thing the next time. I figured the battery was still stock and needed replacing anyway. So I got a new battery. After 5 days, I checked the battery voltage, and its down to 11.7 volts even on a brand new battery. The difference is the new battery at 11.7 volts still starts no problem, where the old battery would barely start the truck. So I needed to change the battery anyway.
I know a battery does not self discharge itself down to 11.7 volts in 5 days, so I measure the current coming out of the battery and its 2 amps! That's huge. No wonder it's draining the battery so quick. So tonight I started unplugging stuff. I first started with all the mods I've done. Still 2 amps. I pulled the main computer cables off and still 2 amps. I even pulled the 7 pin trailer connector off thinking water might have gotten in there and was causing some leakage. No luck.
Anyone have any suggestions I should try?
Make certain you wait until the battery saver times out before looking for parasitic draws.
Normal quiescent draw should be around 50-75 mA.
Also, pull the glovebox and under-hood bulbs to see if the draw goes away.
Steve
Steve
Ya, I agree. But when you go to a dealership to look at a new truck, you know that some of those trucks haven't been started in weeks. Especially since most dealerships have demo vehicles to test drive. None of those trucks have dead batteries.
My understanding of the battery saver is that the truck times out after 10 minutes if the dome lights are on. But I'm doing this test with all the doors shut. No lights are on. But I guess I could hook my meter up in such a way that I could walk away for a while to see if it lowers over time.
I ran out of time last night, but I guess the next step is pulling fuses and/or bulbs. I'm more concerned about a hot wire that might have some corrosion to a gnd. It will be hard to find if that is the case. I guess it also can only be something that is hot all the time. Such as:
radio
starter solenoid
maybe the computer
look for all aftermarket accessories first... things like CB radios/stereo/ PA systems/ stereo amp that the remote wire doesnt turn off/ small lights....
had this problem before, never did find it... but i tore all my stuff out to sell it, and never did it again...
Thank you. This is one of the things I was looking for. A quiescent of 50-75 mA should last about 55 days on a 100 Ah battery. This sounds about right.
radio
starter solenoid
maybe the computer
radio
starter solenoid
maybe the computer
you MUST wait at least 45 minutes to properly test for draw and the door must stay propped open the whole time to prevent "waking" up the system. Ford workshop book says the system will not have more than 0.5 amp draw after 45 minutes.
I had a similar problem with my 07 and it turned out the fuel pump relay was randomly energizing.
I thought the key had to at least be at the accessory position before that relay even got power?
Yes this info should be on the DVD. Go to the battery section and following the diagnoses for battery drain.
Exactly hence the reason I had a problem with my fuel pump relay. With my new fuse box my fuel pump only runs with the key in the on position, before it ran until my battery died or I started the truck!
Spike easiest thing to do it take it to a dealer you trust and have them diagnose it. I am betting it is the fuse box that needs to be replaced. Also when you have this done get a new battery because my bad fuse box toasted my battery.
