changed wiring harness 94 to 95, won't start
Old Nov 2, 2008 | 10:01 AM
captken's Avatar
Hello, I have a 94' xlt with a 351. Turn signal/brake wires melted under dash, damaged fuse box.
I found a truck with the same options but with a 95 xlt with a 302 engine.
Changed out wiring, everything works except no start. Nothing happens when I turn the ignition switch.
Any ideas? What do you think needs modified in order to use the good harness?
thanks in advance,
kenny
Old Nov 7, 2008 | 05:12 PM
captken's Avatar
still working on the problem, making progress, I think once everything is hooked up, it should start. I can start the truck at the solinoid switch and turn the truck off with the key.
any bits of advise from a wiser member?
Old Nov 8, 2008 | 10:52 AM
subford's Avatar
Is one of the trucks an Auto and the other have an standard transmission?
If so tell us if you are going from a auto to std or the other way around.
