Door Open Light Interior Light Wont Go off HELP
Old Oct 4, 2008 | 01:19 PM
clee1052's Avatar
When I close my door the door indicator stays on, along with the interior light, and exterior bed light. I had to pull the fuse to turn them off. What is broken, it must have something to do with the door. But what needs to be replaced? Where is it? The old days there was a lever in the jam, I do not see it... HELP ME PLEASE!
Also when I reset my trip, sometime the mileage indicator goes out, I have to hit the button numerous times, or just wait and it will go on. The truck has 54000 miles on it....Wow...
Thanks Guys!!!!
Chris
Old Oct 4, 2008 | 01:43 PM
beckerjs's Avatar
wd-40 all the latches and do a search for the odometer fix
just looked, go to the electrical main page and at the top, STICKEY's
Old Oct 4, 2008 | 02:58 PM
mbrown29's Avatar
first try undoing the battery and leave it unplugged for 30 minutes... plug it back in and see if it does it still. it might just need to be re-set
Old Oct 5, 2008 | 04:17 PM
clee1052's Avatar
WD 40 in the latch worked thanks, now I need the other fixes...Tinme for another post!
Old Oct 5, 2008 | 11:23 PM
SSCULLY's Avatar
Did you read the other sticky at the top of this forum ?
beckerjs made note of this, it is right below the dor latch sticky that you replied in.
https://www.f150online.com/forums/el...er-repair.html
