stereo resets with door open
Old Sep 28, 2008 | 11:42 AM
kornlizard's Avatar
hello I have a 2006 f150 supercrew 4x4 lariat it is also my first ford truck so everything is new to me.
ok my problem is that with the door open for about 30 seconds the 6disc head unit resets itself hmmmm and says low battery on the display.
i have no problems starting the truck is there something im missing.
If the battery is that low it wouldnt start would it. confusing me to heck
please help
Old Sep 30, 2008 | 11:24 AM
TbaggsTruck's Avatar
I am not sure about this, is there a small battery in the stock radios?
Old Oct 1, 2008 | 03:26 PM
kornlizard's Avatar
think i found the problem
I was wondering if the head unit had a battery too. good thinking!!!
I checked the voltage of the battery while running all is well charging etc.
then i let it run it self down to a level voltage which was 10.9v.
thinking to self should be around 12.? opened the door to activate timed lights. watched voltage drop drop 9.?v not good at all lights went off voltage jumped up again. turned the key to run and voila the head unit goes to low battery mode and resets at 9v and below. I had no idea the that there is a power protection for starting guess there is . well to shorten this lol a new battery was the fix . it was stong enough to start the truck just not run all the acc 2 yrs for a batter yuck off to fun with my first ford yippeeeee
