buhweet1
Old Sep 26, 2008 | 11:38 AM
buhweet1's Avatar
check engine light stays on
My check engine light won't go off. I tried an add on gas saver (supposedly) it didn't work. The instructions said to disconnect the iat(intake air temp.) sensor and install the chip ( gas saver) and the light will come on and then go off. But it was a scam and when I reconnected my iat sensor the check engine light won't go off. I have a 2003 f-150 crew cab with 40,000 miles. It worked fine before the chip installation. Any suggestions? Thanks
Old Sep 26, 2008 | 12:50 PM
Dankle666's Avatar
Is it one of these? http://slrmotorsports.com/shop/index...t_detail&p=252
Old Sep 26, 2008 | 01:23 PM
buhweet1's Avatar
slr
yes it is.
Old Sep 26, 2008 | 01:27 PM
Try disconnecting your battery for 30 minutes and see if it goes away.
Old Sep 26, 2008 | 01:29 PM
buhweet1's Avatar
Thanks I'll try that and let you know how it turns out.
Old Sep 26, 2008 | 02:08 PM
buhweet1's Avatar
Guess what? It worked. You are a smart man, and I want to thank you very much for your help.
Old Sep 26, 2008 | 02:09 PM
Not that smart, just remembered it from on here. Glad I could be of assistance, and welcome to the site.
