Battery life
Old Sep 20, 2008 | 06:10 PM
pylons26's Avatar
Battery life
How long does a stock battery last? I just bought an 05 FX4 and
was curious what kind of life span I can expect.
Old Sep 20, 2008 | 06:35 PM
cva-59's Avatar
Battery life
Battery life depends on many factors. Weather conditions, number of times that the engine is cycled(# of starts and stops), condition of the charging system etc. I would think that you should start thinking about replacement soon. Replace with the largest and the most powerful battery that will fit (number of cold cranking amps) in the vehicle. As far as brand, I would go with a Motorcraft, Optima or Interstate. Sears do not die hard, they die easy. Hope this helps
Old Sep 21, 2008 | 10:46 AM
fairlaner's Avatar
I replaced the stock battery in my '99 about 6 mon ago.
Old Sep 21, 2008 | 11:32 AM
I had planned on replacing my OEM battery in October when it would be 4 years old. It did not make it. Quit dead on me last week, left me stranded with absolutely no warning.
Old Sep 21, 2008 | 06:52 PM
pylons26's Avatar
Thanks for the info. I think I'll end up replacing
mine this fall.
Old Sep 21, 2008 | 09:52 PM
04f150stx's Avatar
My dad still has his stock battery in his 99.
Old Sep 30, 2008 | 11:21 AM
TbaggsTruck's Avatar
04 FX4 64k miles and the battery hates rain or being parked on dirt, it wont start well in moisture. A jump here and there and a decent drive brings it back to life but the moment it gets rain (under an hour) or sits on dirt (overnight) and I need a jump again. This all started when I jumped a big desil. The battery has been killed by the stereo several times as well. I know, I abused it.
Has anybody ever put in a marine battery (deep cycle)? The cranking amps match up well, the stock is 650 and the marine is 700 @ 32 F. I have to check if it will physically fit. I was thinking about it so I could listen to the radio with the truck off, longer than 20 minutes. I have a couple of amps for the stereo. Has anybody done this? Can it be done?
Last edited by TbaggsTruck; Sep 30, 2008 at 11:23 AM. Reason: forgot to put something in
Old Oct 1, 2008 | 06:24 PM
FX41's Avatar
The OEM batt in my 02 is dieing slowly....thinking about just getting one before I get stranded.
Had to jump it a couple times in the last month or so.
Old Oct 1, 2008 | 07:13 PM
FX41's Avatar
I take that back......going to get a new one tonight
