f150 charging problem
Old Sep 19, 2008 | 09:02 PM
popeye1109's Avatar
On the way home tonight all my gauges and radio quit working and my ABS light came on. After I got home and turned the truck off it wouldn't start back up, it just clicked. I jumped it then pulled the negative terminal from the battery and it quit again. Do I need a new alternator?
Old Sep 19, 2008 | 09:16 PM
What year?
Old Sep 19, 2008 | 09:20 PM
popeye1109's Avatar
2004 f150 supercrew with the 5.4
Old Sep 19, 2008 | 09:21 PM
It helps if you have the truck and year info in your profile, or if not, include it in your question. I have been told that the old method of checking the altenator does not work on the newer trucks. That the battery must stay hooked up. I would bet that you have a bad battery. Mine quit instantly, last week. No warning at all.
Old Sep 19, 2008 | 09:22 PM
popeye1109's Avatar
ok thanks......i'll get the battery checked first
Old Sep 19, 2008 | 09:23 PM
How old is the battery?
Old Sep 19, 2008 | 09:25 PM
popeye1109's Avatar
The reason i though it was the alternator was because after I jumped it i noticed that the volt gauge was kind of low. Didn't really go up when i reved the engine and of course went down when I turned the headlights on.
Old Sep 19, 2008 | 09:26 PM
popeye1109's Avatar
battery about 2 plus years....probably close to three
An actual volt meter or the in-dash gauge?
Old Sep 19, 2008 | 09:28 PM
popeye1109's Avatar
in dash gauge
That is not very old. Mine was 3 years, 10 months. Supposed to be a 6 yr battery.
Old Sep 19, 2008 | 09:29 PM
popeye1109's Avatar
down here in sw fl the heat kills them pretty quick......I can pull the battery tomorrow take it in and have it checked....if it's good i'll buy an alternator. If it's not I'll buy a battery
Old Sep 19, 2008 | 09:30 PM
in dash gauge
That thing is not reliable, it just tells that there is a charging problem. Could still be the battery.
Old Sep 19, 2008 | 09:31 PM
Ok, good luck with it!
popeye1109's Avatar
thanks..........it's got to be one of the two
