Dead headlight....
Old Sep 17, 2008 | 12:41 AM
JayPhoenix's Avatar
Dead headlight....
Ok my 1997 has a dead light wire on the driver side, High and driving works (same wire of course, lol) but low beam on drivers is getting no current... where should I start tunneling.... HELP PLEASE
Old Sep 17, 2008 | 02:10 AM
code58's Avatar
The low beams should be fused separately. Check the fuse. High beams are normally fused together because they are on 1 circuit. Low beams have separate circuits.
Old Sep 17, 2008 | 11:24 PM
JayPhoenix's Avatar
Ok but it is only a single headlight not working.... should they not be on the same fuse left and right(low beam that is)??? I'll check but I doubt it is the culprit, wouldn't be my luck lol
Old Sep 18, 2008 | 01:55 AM
novsun88's Avatar
Correct. The pair of lows will be on one fuse and the pair of highs will be on another. Check for corrosion on the wires. Work your way back on the wire. They are thin and prone to these issues. Swap bulbs to see if it is not a bad bulb.
Old Sep 18, 2008 | 07:05 AM
Rockcoastie's Avatar
Dead Bulb also....
JayPhoenix, Has this problem been an ongoing issue with your driver's side low beam? The reason I ask is because on my 04', the driver's side low beam was dead last week, I replaced the darn thing, and my luck this morning noticed it was out again. I'm going to start troubleshooting the wiring, but saw your post. Any info is appreciated man.
Old Sep 22, 2008 | 12:09 PM
SSCULLY's Avatar
Not correct.
Driver's side low beam is Central Junction box ( cab fuse panel ) fuse #28 & the right side ( pass ) is Fuse #26 and the DRL module if installed.
1997 Owners manual page 138.
Old Sep 22, 2008 | 12:11 PM
SSCULLY's Avatar
When you replaced the bulb it worked fine ? Then I am going to have to ask the dumb question, did you touch the bulb ( glass ) when you installed it ? If you did, that is why it burned out so quick.
Old Sep 24, 2008 | 05:27 PM
TXhustla's Avatar
Did you check any of the fuses?
Old Jan 20, 2009 | 10:13 AM
JayPhoenix's Avatar
Sorta forgot about this topic... sorry guys.
Problem still exists, it just was like that one day when I started it up. I know it's not a bad bulb, wiring is all intact no corrosion anywhere... will check the fuse and let you know...
Old Jan 20, 2009 | 05:00 PM
SSCULLY's Avatar
You still need to check the fuse, but how do you know it is not a bad bulb ?
Old Jan 20, 2009 | 07:05 PM
JayPhoenix's Avatar
brand new bulbs and used the plug in on other side bulb works great :P really wish ford has labelled the fuses like dodge and chev.... oh well :P will let you know tonight... trucks been parked since August/September pretty much.
Old Jan 26, 2009 | 05:08 PM
JayPhoenix's Avatar
Just a question there SCCULLY where is the DRL?
Old Jan 26, 2009 | 06:12 PM
SSCULLY's Avatar
Did you check the fuses yet ?
This is going round and round, and no note if the fuses are good.
Don't worry about the DRL, until you check the fuses.
BTW : DRL is Day time Running Lamp, it is the bulb at a lower wattage, so where is the DRL, in your headlamp, specifically the bulb.
Old Feb 4, 2009 | 12:55 PM
JayPhoenix's Avatar
LOL thanks all for the help and the "simple" explanation's. Yes it was the fuse finally got around to working on it the other day. And just to clear things up on the DRL thing, yes I know what they are I just am unaware as to where it is located is all .
None the less thanks a million for the help and in the future I will attempt to get on here more often to keep up to date on everything.
