brake light/ turn sig problem
Old Aug 24, 2008 | 11:44 AM
mpack943's Avatar
i have a 98 f150 and recently my rear turn signal and brake light stopped working. The bulb and flasher were replaced a week ago and were checked again after problem started and are good and all other lights work. aany info would help, thanks
Old Aug 24, 2008 | 01:17 PM
scoobydoo1966's Avatar
I am having the same problem. I just got done doing some work on the steering column, and ever since then My brake lights worked for about a day, but turn signals are come and go.
Old Aug 24, 2008 | 02:47 PM
moengle's Avatar
I just had same problem, found broken wire inside behind turn signal switch.
Old Aug 27, 2008 | 10:49 PM
2manydogs's Avatar
I have same problem but now when I turn on signal both start flashing and when I hit the brakes they quit working until I release brakes. Sure could use some help on this.
