No turn signals??? HELP!!!
Old Jul 23, 2008 | 07:34 AM
kcmably's Avatar
Hey guys I have a problem that hopefully someone can help me solve? I have a 1993 F150 and the turn signals quit working. The little green arrows that come on when you flip the turn signal lever dont light up at all. THe flashers work. I checked the fuse and it looks good. What should I check next? Is it the turn lever assembly? If so is that hard to replace? Please help me. Thanks Guys for any suggestions!!!!!
Kevin
Old Jul 23, 2008 | 03:45 PM
rjpf150's Avatar
I had the same problem ,
Heres what happened,when i moved the sterring column down it pulled out a plug connector thats underneath the sterring wheel cover.
After I removed the column cover i found a few tie wraps that were very tight and din't provide enough slack for the wires to moved when the sterring wheel is moved up or down.I basically cut the tie wraps off plug the harness back in and havent had any more problems.
I'll look for your reply GOOD LUCK
Old Jul 24, 2008 | 07:44 AM
kcmably's Avatar
It was the flasher. So it ended up being a easy fix. Normaly my luck doesnt go that way. Thanks for the ideas tho!!!!!
