Question with my Hellas wiring...
Old Jul 18, 2008 | 01:28 AM
meeshforty's Avatar
I found a set of in the box Hella Fogs when I moved into my house. Since I just added a Brush guard, I was going to put them on. They have a wiring diagram, but I think I don't need all the complications in it. It has a lead from the battery to the relay, leads from the relay to the lights, Lead to the switch from the relay, and a lead from the parking lights to the relay? I just want them on an independant switch, not dependant on the parking lights. Can I just run a lead from the battery to the switch with an inline fuse, and leads from the switch to the lights, then ground the lights like the diagram shows? Please let me know, it seems to me this would be the easiest way, I just want to make sure I'm not overlooking anything, it is late, after all. And what size fuse should I use? Thanks in advance!
