Over Drive Button
Old Jun 29, 2008 | 09:06 PM
jrsdar's Avatar
Over Drive Button
My son has a 99 f-150 and the O/D button dose not work, Has anyone had this problem? Anything I can do to see if its the button or just take it to the dealer.
Old Jun 29, 2008 | 09:25 PM
torkum's Avatar
I would check the fuse before taking it in.
Old Jun 30, 2008 | 05:50 PM
jrsdar's Avatar
O/D button
Torkum,
Thanks, the fuse was blown but after replacing it , it happened again, I guess I'll take it to the shop or see how much an O/D button is and go from there
Old Jun 30, 2008 | 07:21 PM
gaforddriver's Avatar
Here is a previous thread on this exact problem.
https://www.f150online.com/forums/sh...d.php?t=332961
Old Jul 15, 2008 | 02:54 PM
mmlorenz's Avatar
Blowing OD Fuse
I had the same problem
Based on recommendations from this site:
I just took the plastic off from around the steering column. Sure enough the shifter had worn away the insulation around the wire for the OD button. I just taped the hell out of it with electrical tape, put it all together again and it works perfectly.
