Help Please No Window Rolls Down Or Up!!!!!!
Ok guys, I have a huge problem none of my windows will roll down the 30amp breaker circuit is fine I still have power to my power moon roof. I cant get any movement from any window no matter which switch I use nothing. Please help I am completely baffled any help would be greatly appricated.
Any ideas? I just replaced the master switch on the drivers door and still nothing? If anyone has any kind of info please please please help. I really dont know where to even begin starting to look.
nope the only thing not working in the truck is the windows. Is there more then one fuse that runs the windows? If I was reading my manual right there is only one fuse to control my windows and power sunroof correct?
I have a problem with my driver door too. I can roll down driver side but it does not roll up. I have to play with it a while and finally it will go up. Can yall help me with this one too.
That one sounds like a bad contact in the switch. Does it work with the other switch associated with that window? If it does you can either replace the switch for around $60 at a ford dealership or find one on the internet reasonably priced. Or read through about the first 2 pages of the electrical forums and there will be a thread on how to take the switch apart and clean the contacts, I think it has something to do with "cheap/free fix in the title" I saw it this morning when I was trying to solve my problem. But yours is a very simple fix. Pm me if you need more help on how to swap out the switches, I can help you with that and it is a very simple procedure it takes maybe 5 min to swap out.
it is the master switch on the driver side. Every other window works up and down and the window lock works too. But it is just rolling up the driver side and it is not all the time. If I hit it two or three times, it will go up.
Yep, no problem.....
Now if I could only manage to get an answer to my problem......
Once I figure it out I will post step by step with pics for anyone else with this problem.
Well guys I found my problem. It was a broken wire. I have a complete write up on how to fix it. The thread is going to be called How to fix a broken door wire. Hope it will help others with a similar problem.
I haven't searched for your write up yet (I'll do that next) but did your window switch lights flicker on and off sporadically when your windows quit working? I stopped and filled up last night and when I left my windows didn't work and the lights where flickering.
