dead pcm?
Old Jun 21, 2008 | 07:36 PM
mikeus02's Avatar
dead pcm?
truck just died last week, battery good, all fuses and relays good, odometer displays ------, if you let the key sit on run for 15 sec, cannot get any codes from scanner, checked pcm connection and other firewall connections for corrosion, did not find any, before i waste money on a new pcm, has anyone had this problem b4 and have any information????? 2002 150 4.2l no mods
Old Jun 21, 2008 | 08:15 PM
3F150's Avatar
If it cranks over but dose not fire, clean your MAF sensor.
Old Jun 21, 2008 | 09:31 PM
torkum's Avatar
Sounds like a GEM problem. Check under the dash for any signs of the windshield leaking around the fuse panel.
Old Jun 22, 2008 | 09:14 AM
projectSHO89's Avatar
Please avoid cross-posting between sections.
Try to keep everything related in a single thread in the most appropriate section of the forum.
Steve
Old Jun 22, 2008 | 04:24 PM
LastSplash's Avatar
If your check engine light comes on when the key is turned to the run position then the PCM is good.
Old Jun 22, 2008 | 05:09 PM
crash_lucky13's Avatar
there's a few things that could have happened man. unfortunately NONE of them look good. is your theft lift flashing? because of our trucks (i have an 02 that got the pcm erased accidently by autozone..) PATS system, there's a way to tell by the 'theft' flashing. i can't remember exactly what it was, but search around.
also, bad news man but i spent close to $800 for a new used one, reprogrammed and reinstalled in the truck. you also have to get your keys rescanned if it died... pm for more details if you need them.
~Crash
Old Jun 23, 2008 | 11:16 AM
mikeus02's Avatar
when you first turn key to on position , the dash is dead just door ajar light on, and theft blinking fast, after 10-15 sec the guages start working, service engine soon comes on and theft light starts blinking a code like the old obd1
1 flash then 3 flashes it repeats this over and over, no leaking windshield, does the anti theft kill all of this?
Old Jun 23, 2008 | 11:26 AM
mikeus02's Avatar
my apoligies steve
i am new, and thought i should have posted in this section in the first place
truck is a crank no start
has factory theft system
have never had any dash dtcs
it is sounding more and more like the pats, because the fuel pump is not working, and all the connections to that look good
Old Jun 23, 2008 | 12:59 PM
i would say it's looking more like your pcm in man. get it towed to the ford place and they can run diagnostics on it. you'd be suprised how EASY it is to fry those things. mine was doing the SAME thing. regardless you have to get it reflashed at ford, so go ahead and take her on over...
Old Jun 24, 2008 | 09:06 AM
mikeus02's Avatar
Angry
I was wanting that to be a last resort, but like you say if it is the pcm or the pats i don't have the tools to reprogram, only the dealer does. i guess they do things like that to stay in buisness. I was hoping it was a hidden short or something. driving a back up vehicle now. will take to dealer in a couple of weeks, let you all know how it turns out.
Old Jun 24, 2008 | 09:45 AM
pull your old one and get the digits off of it and start looking around for a good used one..that's usually the CHEAPEST way out.. that's what i ended up doing.
Old Jun 24, 2008 | 11:20 AM
Look in the OTHER thread you started.
It has information you need to read.
Steve
Old Jun 24, 2008 | 11:59 AM
scott.joyner24's Avatar
there's a relay if I am remembering correctly that might be out. I'll check for you. It would be cheaper than a new pcm.
Old Jun 25, 2008 | 08:59 AM
mikeus02's Avatar
i swapped the relays between the fuel pump and the pcm because they are the same, this was one of the first things i did, i don't see both of them being bad but i have seen stranger things, new ones only cost about $10 bucks each so I will pick up a new pair, does anyone know readings i should be getting from the socket? to see if there is a problem b4 it gets to the relay?
