HID install question
Old Jun 7, 2008 | 05:56 PM
th3godf4th3r's Avatar
ok so i just got my HID's from HID4U and have some question
1) on the relay there is three wires connected to it, only about a foot long or so and they are colored blue,black and white
Where do these need to connect to?
Old Jun 7, 2008 | 06:56 PM
mSaLL150's Avatar
Those go into the passenger side stock harness (the harness that is attached to the back of the stock bulb).
Black is the middle. blue and white on the outsides, try them on both sides until your high and low beam are correct.
Old Jun 7, 2008 | 07:05 PM
ok well i just tried what you said and i get nothing from sticking it in the stock harness, so i tried plugging the orginal halogen bulb back in and i get nothing from the passenger side but if i go over to the drivers side the bulb works fine
Old Jun 7, 2008 | 07:31 PM
mSaLL150's Avatar
put your stock bulbs back in, then instead of turning the headlights on, when its night time turn them to (auto) aka turn the dial left, it will re-dial your stock bulbs. then do what i said to do with the HIDs.
Old Jun 7, 2008 | 07:43 PM
ok it was just a blown fuse thats why it wasnt working
so i dont think black is middle because when i put a new fuse in i put black in the middle and white and blue on the outsides and it blew the fuse again. i dont think it would blow it if i got the blue and white mixed up.
if i have the relay do i need to splice/tap into the stock wiring?
Old Jun 7, 2008 | 08:41 PM
mSaLL150's Avatar
nope, no tapping required. sry about the fuses. For mine, the black wire (ground) goes in the middle. must be different for yours. Make sure that...
a) you havent hooked up the red wire to the battery yet. That will blow fuses.
b) your prongs DONT TOUCH EACH OTHER.
c) the key isnt in the truck w/ the headlight switch on while you're wiring this stuff.
Old Jun 8, 2008 | 02:56 AM
alright well ill try again tomorrow and report back
thanks
Old Jun 8, 2008 | 07:52 PM
so i got the passenger side light to work and now the drivers side light wont work.
i did accidently cut the ground wire that comes from the bulb in half but i put it back together with a wire tap. that didnt seem to work
tomorrow i will solder the wires back together and see if that works
but until then if you guys think there is something else im missing let me know
i didnt have to plug the little prongs into the drivers side headlight too right? because there are no little prongs to plug in on that side
Old Jun 8, 2008 | 08:17 PM
shaunakadub's Avatar
No, you should only have to use the passenger side factory harness. You can tape off the drivers side one so no water gets in there.
Old Jun 8, 2008 | 09:24 PM
yeah i taped it off pretty good, so do you think its just because of the ground wire?
Old Jun 9, 2008 | 12:52 PM
ok so i just soldered the two ground wires back together and plugged it in and still there is nothing.
what do you guys think it could be???
no blown fuses
and i just switched the lights to see if that would work and it does so im thinking is has to be a bad ballast?
