What to do
What to do
ok im a big goose hunter and tow a little 6x12 trailer around to haul all the hunting stuff and i use the 4-pin to hook the lights up well the ports inside the 4-pin corroded and rusted so i tried to clean them out and i ruined the 4-pin pod what do i need to do i know they make aftermarker 4 pins or do i go to ford i dont know if ford sells just the 4 pin i think you got to buy the whole harness but i dont need the whole harness so should i just buy a after market one and one last thing are they easy to install
What to do - 4 Pin Trailer Lights
You can go to any parts house or Wally World and find the the necessary connector... the wire colors are standard and should be the same to identify the various circuits (L & R turn, running lights, return ground). If they aren't, then you need some kind of circuit tester to I.D. the wires, whether it's just a 12 volt bulb or a voltmeter. After you have the wires identified, cut the old connector, strip the ends, and splice the wires. Wire nuts are easy, butt slices are okay, black electrician's tape will do. Depending on the length of the wires of your replacement connector, you will probably want to make the splice as far back as you can, both for "beauty" and more protection.
