wipers not working
Old May 18, 2008 | 09:02 AM
thegoods's Avatar
wipers not working
Help. My wipers, int. lights, and washer are not working. Replaced multi function switch and tried new wiper motor. Fuses and relays seem ok.
1998 F150 4.2L auto
Old May 18, 2008 | 10:13 AM
keith97xlt's Avatar
pick up a haynes manual. it has all the wiring diagrams in back. its rare for wiper motor to go.
Old May 18, 2008 | 03:55 PM
SSCULLY's Avatar
Few questions.
Q1. Has it been raining a bit in your area ?
Q2. When you say interior lamps, is this with the door only, or also with the interior light switch ( instrument dimmer switch ) as well ?
Test items on the wiper ( the relay is in the Battery Junction Box, aka BJB, or under hood fuse panel )
T1. pull the wiper hi /lo relay and jumper pin #3 to pin #4 ( low speed )
T2. jumper pin #3 to pin #5 ( hi speed ).
For the above tests,This should be the relay piin out, I think it is a half size relay.
Good luck, let us know the answers to the above, and we can move forward from there.
Old May 18, 2008 | 09:49 PM
thegoods's Avatar
wipers not working
1. It has been raining quite a bit over the last month.
2. No interior light or map lights by door or switches
3. Assuming had correcte relay. #3 in BJB (W/S/W, HI/LO) jumped 3 to 4, and 3 to 5, no dice.
Old May 18, 2008 | 10:35 PM
projectSHO89's Avatar
Sounds like another leaky windshield and water got into the usual suspects.
