power windows and door locks not working out of blue ?? any help ???
Old May 11, 2008 | 10:42 PM
painter338's Avatar
hi guys so ill get right to the point i have a 97 f250 light duty and recently the power door locks on both doors just stopped working out of the blue from both switches . they were not sluggish befor they stoped working nor did i have anty problems with them before that . well i let it go then about a month later or a week ago my driver side window just started rolling down all by itself ( the other one was fine) well that went on for 2 days then out of the blue both windows just stopped working also from both door switches ? i can here a relay clicking once in a while in the fuse box under the steering wheel but i have no clue what that meens ? now my driver side window is stuck down and it really sucks haha so any help would be greatly appriciated thanx
Old May 11, 2008 | 11:12 PM
rednoved's Avatar
im not sure what the problem is. but i would check the fuse box. maybe its not a relay clicking. maybe its a fuse blowing. wish i could help.
Old May 12, 2008 | 12:43 AM
Paralyzer's Avatar
i will bet if you look inside the boot from cab to door you will find broken wires in there. its a common issue on older trucks just from the door opening and closing. seen it cause your exact issue many times.
Old May 12, 2008 | 03:04 PM
painter338's Avatar
so i checked all that stuff and i couldnt figure it out so i brung it down to the garage and the told me it was my gem module and fuse panel ! great haha
