Installing Automatic Headlights on 04+ F150's?
Old May 5, 2008 | 02:41 PM
SunnDogg's Avatar
I've serached through this forum and others for info/part #'s on installing the automatic headlight feature and found several for the '03 and older styles, but nothing for newer models. I traded my '05 FX4 off for a more basic '08 STX and would like to install this feature as it is one you really get used to having and don't realize how much you miss it until its gone. It is the Sport model that has fog lamps as well as what appears to be a dummy photocell in the dash. Does anyone know the part numbers for the switch itself and the photocell? Are there any other parts that are required? Thanks in advance.
Old May 5, 2008 | 03:54 PM
CANES676400's Avatar
if you find what you need do you think you could do a little write up because i was thinking of doing this also
