Power windows
Old Apr 17, 2008 | 09:56 AM
Pheonixx's Avatar
Power windows
using the auto power window on the drivers side it goes down, makes a few clicking noises on the way but when it hits bottom it stops and kind of gorans like the motor is still trying to make it go down but cant. wondering what causes this and how i could remedy it.
Old Apr 17, 2008 | 07:47 PM
02SC4x4's Avatar
take the panel off the door and look at it, and if the motor is trying to run the window into the ground, you most likely have a problem with the limit switch. i wouldnt use the auto down if u can help it, by having the motor strain itself youre going to eventually burn out the brushes, and that would result in a new motor.
Old Apr 18, 2008 | 11:07 AM
Pheonixx's Avatar
thanks
where is the limit switch located? or is it obvious and easily found?
