Airbag light
Old Apr 8, 2008 | 05:44 PM
jetlag's Avatar
Airbag light
Yes, I searched and there was a lot of info but I couldn't find my specific code.
When I start my truck the airbag light in the guage cluster flashes 4 times then 7 times, then 4 times then 7 times and it does it a few times then stays on.
What is this one?
Old Apr 8, 2008 | 07:00 PM
cva-59's Avatar
What is this one?
Are you sure of the count. My chartsshow no lfc 47 code??
Old Apr 8, 2008 | 08:34 PM
projectSHO89's Avatar
You need a new chart.
See Electrical forum. I just answered this a day or two ago.
Steve
Old Apr 9, 2008 | 02:21 AM
jetlag's Avatar
Steve
Steve,
How do I disarm the SRS? and what does RCM mean?
LFC 47 indicates there is excessive resistance in the passenger-side belt pre-tensioner circuit.
Disconnect the battery and wait one minute to disarm the SRS.
Inspect and reseat the connectors at the RCM and at the passenger-side belt pretensioner.
Old Apr 9, 2008 | 07:54 AM
Steve,
Disarming takes place when the power is removed and the internal backup supply discharges (the one minute delay).
RCM= Restraints Control Module (the computer that runs the system). Depending on the model year, it is either under the passenger seat, under the dash on the center tunnel, or is behind the glovebox.
Steve
Old Apr 9, 2008 | 11:39 AM
jetlag's Avatar
My truck is a 2002..
Old Apr 10, 2008 | 03:13 AM
letzgo4wheelin's Avatar
This just happend to me last week. My problem was one of the wires in the plug under the passenger side seat was loose and not making a conection.
Hope this helps
Old Apr 10, 2008 | 11:56 PM
vuk75's Avatar
I started having an issue with my air bag light blinks twice then 7 times any ideas???
Old Apr 11, 2008 | 12:13 AM
02SC4x4's Avatar
lfc 27 is telling you the passenger airbag off lightbulb is burnt out, or not plugged in.
when you turn the passenger airbag off does the "off" light come on?
if not the bulb is burnt out or it may be just unplugged at the back.
Old Apr 11, 2008 | 10:47 AM
vuk75's Avatar
thanks for the input. Ill check it out
Old Apr 11, 2008 | 05:58 PM
jetlag's Avatar
Hope this helps
I went to check the yellow connector under my passenger seat and as soon as I touched it the wires fell out! Haha, loose connection for sure...
But I hope I put them back in right....did the yellow/red stripe wire go with the blue wire? and the yellow/black stripe wire go with the red wire?
That's how it is on my driver side except replace yellow with green.
If I got it right, then why does the light still stay on?
Old Apr 14, 2008 | 01:44 AM
jetlag's Avatar
Well, I took it to a dealership, and I thought I had fixed it but they said the "pretensioner connector" was bad and needed replaced.... are they talking about the yellow connector under the seat???
They said it would be $250 to fix it..haha wow
Old Apr 14, 2008 | 09:06 PM
jetlag's Avatar
Anyone?
Old Apr 15, 2008 | 08:24 PM
jetlag's Avatar
Problem solved.
I just had to get some needle nose pliers and pull the wires through the connector til they locked in place!
Old Apr 16, 2008 | 12:35 PM
SIK-06's Avatar
Mine just started blinking Once then 8 times so from what ive gathered from this thread its an IFC 18 code. Can anyone tell me what that means?
