04 F150 Problems
Old Apr 7, 2008 | 02:28 PM
NGibbons55's Avatar
04 F150 Problems
Hey Guys Im Having A Few Problems With My Truck, First Off The Cruise Control Wont Work, The Fuse Is Not Blown. And Second My Shifter Wont Shift Out Of Park. The Brake Lights Are Working, And The Fuse Is Not Blown. Has Anyone Had The Same Problems Or Know How I Can Fix These??? Thanks In Advance!!!
Old Apr 7, 2008 | 11:59 PM
02SC4x4's Avatar
i cant remember the exact name of the fuse, or the location where it is. i think it goes by something like "ignition interlock".
check all your fuses in the cab and engine and you should find the one.
if you really need to start the truck you can just put it in neutral and turn it over.
when you find the fuse and replace it, if it keeps blowing you may want to dig a little deeper into the issue.
Old Apr 8, 2008 | 07:54 AM
projectSHO89's Avatar
Probably a bad brake light switch.
Steve
