Keypad
Keypad
Ford sells a stick on keyless entry pad for the door. It states that this jsut works like the keyfob. My question is if I were to buy a set of door handles that have the keypad do they work the same way? I was wanting to pick up a set of Mark LT handles.
someone else may be able to tell you more, but when u say "works like the keyfob", i am assuming it would be a wireless keypad, in which you only need to run a power and ground wire to it.
as for the mark LT handles, you would need to check and see if you have the wiring/harness for the keypad.
The door handle keypad is wired to the truck, and uses the keypad function of the VSM/BSM.
The stick on keypad is another RKE, that is programmed the same way as RKE fobs.
2 different keypads
2 different keypads
Originally Posted by Dragoon41
Guess I won't be able to just install them and plug into pre-existing wiring then. Oh well, Thanks for the info.
My 2001 ( slightly different ) had everything needed, I just had to buy the handle and the keypad.
Take a read through the threads.
Keypad
