Need help plz.......
OK I Installed some fog lights to the rear of my truck..For added light backing up I wired it to my wire feeding the back up lights ...After i hooked up the white wire and had the light mounted to the frame of my hitch ..Had wife turn switch on and put it into reback...boom lights worked fine..Ok i didnt hook up the ground thought i was grounding out to the frame.. OK now the next day my abs and brake light came on on the dash as if the ebrake was on..so i found its a blown fuse no biggie..changed fuse ..very next day light on again..Now my ? is by me not wiring up the ground is it feeding back or grounding it self out though the fuse box or what plz help ...I really dont wont to add a switch inside my truck just for these lights.....??????
Originally Posted by grizzly_2008
what you thinkl about changing the fuse from a 10 to a 15 amp?
Did you hook these up to the truck's backup lights or to the 7 pin trailer tow adapter's backup circuit ?
The reason I ask, is the truck's backup circuit will not take a 2 A load too well, let alone the load these lights are adding.
I did a test with some Truck-Lite backup LED lights, just to have the info ( was installing to the 7 pin adapter backup circuit ). The truck's backup circuit woudl run a single 1 A backup lamp OK, but adding the second 1 A light, both lights dimmed ( would not drive a 2A load ).
You are better off using the backup circuit in the 7 pin trailer tow adapter, or using the truck's backup circuit to trigger a relay.
This is too much load on the circuit, and it is possible that you will have problems with the DTR sensor later ( the part that switches on the backup lights ).
Here is one thread on the topic :
https://www.f150online.com/forums/sh...ghlight=backup
Here is another method, draw using the EVTM pages as a ref, using the trailer tow battery charge circuit ( 30A fuse ? ) as a ref :
