AAHH NUTS !! guage sweep problem is back
Old Mar 6, 2008 | 05:27 AM
l.spall's Avatar
My 1999 F150 had a guage sweep problem on start up a few months ago, I replaced the battery and the problem went away. Now its doing it again, mostly if the truck hasn't been running for a few hours. any thought?
Old Mar 6, 2008 | 05:57 AM
mjd5.4's Avatar
gauge sweep
So what you saying is when you turn the key to start truck the dash gauges sweep all the way to one side and comes back?
If thats whats happen, it could be windshield leaking or moisture getting to where your computer is located, causing this problem.
That happen to my truck just recently, since my windshield was cracked I had it changed, solved my problem!
Old Mar 6, 2008 | 06:14 AM
02SC4x4's Avatar
im gonna say ur battery is perfectly fine except for the fact that its not charged fully. however, it could be a lemon.
im going to suggest your alternator is bad, and because the battery was new it managed to keep the new battery decently charged for a while. but now the alternator cant keep up with the current draw, and isnt properly charging the battery.
try putting a battery charger on the battery, and get it fully charged while its sitting. then turn it over and see if they sweep. if it doesnt sweep after u charge the battery, the alternator is going out.
if youve never replaced the alternator, its probably time, it is going on a decade.
Old Mar 6, 2008 | 07:50 AM
l.spall's Avatar
Put a battery charger on it to see what happens, but before I did I checked the voltage with my multimeter, it read 12.4
Old Mar 6, 2008 | 06:39 PM
02SC4x4's Avatar
it should be reading in the range of 13.8/14v.
when u turn the truck over its probably dropping the voltage to around 11v (from 12.4), which is to low so get the sweep.
