Hard wireing
Old Mar 3, 2008 | 09:19 PM
Ricko's Avatar
Hard wireing
I have a Garmin GPS and a radar detector i want to hard wire. My cigaret lighter has constant power even when the engine is turned off. So i bought a second set of cigaret lighter ports that i can pinch onto another wire. I am not sure which wire i can pinch that turns off when i turn the engine off. I dont wana pinch an important wire that could cause me problems. Any suggestions or easy way to find out?
Old Mar 3, 2008 | 09:33 PM
novsun88's Avatar
Do you have an aftermarket or stock radio... If your up to that its the black with pink stripe that has a switched 12V power source.. I believe that to be your best bet. There are ignition wires to cut but that is risky
