speedometer frustrations
Old Feb 23, 2008 | 09:13 PM
trauts's Avatar
my speedometer no longer works, but i did check with a obdII and its functional that way (auctual drove while hooked-up) have checked every fuse and changed the sensor on the tranny and still no mph on cluster any suggestions would be helpful.
p.s all my guages are working (gas, oil temp and amp! good to go.
alabama
Old Feb 24, 2008 | 08:48 AM
torkum's Avatar
What year do you have If you have a '99 up did you read the sticky in this section?
Old Feb 24, 2008 | 10:59 AM
R1Jester's Avatar
Correct me if I am wrong, but doesn't your truck have a mechanical gear in the rear end that measures speed off the pinion? Have you checked that? Top of the pumpkin on the drivers side I think...
Old Feb 25, 2008 | 04:14 PM
trauts's Avatar
spedometer
1997 f150 regular cab
