Drivers Window Does not work
Old Feb 23, 2008 | 04:27 PM
fgbsr's Avatar
My drivers window won't go up only a cliking noise comming out of the fuse?
Old Feb 23, 2008 | 07:03 PM
joshmac4.6's Avatar
Fuses don't click. What vehicle is it?
Old Feb 24, 2008 | 11:22 AM
ford24s's Avatar
window
is the switch you need to buy the whole switch, even do the other windows work fine, the main control switch is a single unit, be ready to spend about $90 dls and not you can not fix it. I try it on mine. good luck...
Old Feb 24, 2008 | 02:18 PM
SSCULLY's Avatar
Sounds like the same symptoms my dad's 2001 had, try this thread :
https://www.f150online.com/forums/sh...ghlight=window
Old Feb 26, 2008 | 08:22 AM
jaysson2's Avatar
window problem too
I have a 2006 fx4. About six months ago my driver window started have problems rolling up. Goes down fine and all other windows operate normally. Took truck to dealer - TSB said reset a clamp or something to release excess pressure on window guide. That worked for a llittle while, same problem is back. Window will go down fine, auto down too, but on closing....window acts like it is stuck and moves only 1/4" at a time if at all. I found putting pressure on window in various directions would help, but I dont want to burn the motor up! Any ideas?
Old Feb 26, 2008 | 09:18 AM
BLUE20004X4's Avatar
Buy up used switches from ebay, sounds like that's what it could be. I wouldn't doubt the window motor most likely what it is.
