Power Windows, only work from master switch
Old Feb 22, 2008 | 11:12 PM
caper28's Avatar
Hey, I have a 2006 F150 XLT. The power windows only work from the master switch on the driver side. I checked the window lock switch and the wires going to it, seems to be ok. Anyone have any ideas. Maybe something else I should check.
Old Feb 22, 2008 | 11:44 PM
02SC4x4's Avatar
if you didnt take it right apart, then u should do that. the lock out switch is only a little piece of metal that "see saws" over a pivot and completes the circuit to the other doors when in the unlocked position.
basically if this little piece of metal has somehow fallen off, or if the pivot has broken and the metal "see saw" cant complete the circuit then u have your problem.
if you scroll down to the #2 post in this thread you can see a sideways "L" and a little metal pivot point.
https://www.f150online.com/forums/sh...ock+out+switch
hopefully u get what i mean now. i guess it could be dirty/corroded somehow.
good luck.
Old Feb 23, 2008 | 12:05 AM
caper28's Avatar
I get what your saying. I never took it compleatly apart, just tested the wires to see if there was a current going through when in the unlock position. There is a current when in the unlock, which led me to believe the switch was working.
