Yellow Parking Light Wire
Old Feb 14, 2008 | 10:30 PM
steelshot220's Avatar
I just bought a Westin bull bar with the driving lights... ive got all the wireing figured out but the yellow parking light wire.
can someone help me out where am i supposed to connect this, or is there a better place to plug it up than the normal?
thanks
Old Feb 15, 2008 | 11:28 AM
2stroked's Avatar
Without seeing the rest of your wiring diagram, answering your question will be difficult. Did the set come with a relay?
Old Feb 15, 2008 | 01:07 PM
yes it did... relay and switch...
do you think that wire is just the power wire? and that it would normaly be taking the power from the parking lights? cause in that case i can just splice it into the cig light power....
Old Feb 15, 2008 | 02:04 PM
2stroked's Avatar
It might - and I repeat might - be so that you can only run the lights when your parking lights are on. If that's the case, you might want to make sure that circuit is properly fused for the additional load. If it's just the trigger for the relay, it's very low.
