2003 f150 overhead console
Old Feb 14, 2008 | 07:20 PM
crawler_81's Avatar
I have a '03 f150 XL extended cab , truck is pretty plain , I want to put a overhaed console it, not sure how hard it would be wire it up and get the temp working, I have found a '02 ford that has the console in it, what all would I need to get of the donor truck to make it all work and where is the emp sender located
Old Feb 15, 2008 | 02:07 AM
AlfredB18's Avatar
Well, the wiring should be tucked in the headliner already.
You probably just have to punch into the headliner with some screws and I suppose there are a few spots to screw into to keep the console in place.
I'm just guessing on that, since it doesn't seem like my truck's headliner is specially cut out for this.
You might be having to grab a fuse or relay and pop them into their proper spots and I have no decent wiring schematics to tell you where to find any needed sensors.
Maybe someone with a factory manual will chime in sooner than later.
