My wiper/turn signal switch is messed up
the turn signals only wrk when i hold the lever in the temporarily on position. do i need a new switch or can i fix this problem? where can i get another switch if i need? my truck is a 98 f150 v6/automatic. thanks for the help
it is the plug on the back of the switch. i'll bet it works when the wheel is tilted up all the way, if so just take all the plastic off and the key switch out and use some tie straps to hold it in place. when you move the wheel down it pulls the plug on the back off when you tilt it up it pushes it back on. i had to do it to mine and it is very easy to fix.
