No taillights or plate lights
Old Dec 18, 2007 | 03:55 PM
Nix02Screw's Avatar
Exclamation No taillights or plate lights
Hi I have a 2002 Supercrew and yesterday my taillights and plate lights quite working. I have checked all the fuses both in the cab and under the hood. My front marker lights, brake lights, reverse lights and all trailers lights work. I have read some posts about this but couldn't find a definite answer. Any help would be great. Also if anyone has a wiring diagram for this vehicle that would really help to. Thanks for your help.
Old Dec 19, 2007 | 08:02 AM
projectSHO89's Avatar
Download both of these files for the chematics for the exterior lamp circuit for your truck.
http://www.mediafire.com/?2medtmexxge
http://www.mediafire.com/?1nzwvcybglt
You have a damaged (open) circuit somewhere between the splice inthe engine compartment and the rear of the truck. There are several connectors in the rear that would bear taking a visual - labeled as C411 and C405. C411 is on top of the frame rail above the axle on the driver's side, C405 is rearward. Look for corrosion or pushed pins, etc.
Steve
