ABS light
Old Nov 28, 2007 | 07:00 AM
paulwhittom's Avatar
ABS light
Not sure if I should post this here or in the brakes section, but I'm hoping you guys can point me in the right direction. Is there a way to shut the ABS light off. I know the 2 sensors on the front hub assemblies are damaged and are causing the light to come on. I recently changed the front wheel bearings and don't want to change them again just for the sensor. Asked to see if you can just replace the sensor and was told no. I just really hate staring at that light. The truck is an '03 supercrew 5.4 4x4. Thanks guys.
Old Nov 28, 2007 | 08:39 AM
projectSHO89's Avatar
Originally Posted by paulwhittom
... Asked to see if you can just replace the sensor and was told no.
Whoever told you that was wrong.
You can put black tape over the light, remove the bulb, or fix the real problem...
Steve
