Power points
Power points
Hi, I have a question regarding the power points in my 04 F150, the other day I unplugged something that was in the port on the dash, well, it fell apart and the tip and fuse and spring stayed inside. When I attempted to get them out there was alot of sparks and stuff. Now it doesn't work( the other 2 still work) I looked in the book but could not find a listing for this plug. There is a seperate fuse for the "cigar lighter" and one for the "rear power point". Everything else seems to work normal. It would be a real pia to check all the fuses either by pulling or with a test light. Any suggestions?
Go to this site: http://www.genuineservice.com/genuin...ault?page=Home
Click on OWNER GUIDES Fill in the info and down load the owners Manual. Page 199 fuse 41.
JMC
JMC
Thanks for the quick reply, that fuse is for the "cigar lighter", that outlet is working, as well as the one in the rear seat area. The outlet that I am having problems with is the one located in the dash. I can't figure out why they would have a seperate fuse for each outlet but not have a listing for the one in the dash.
