Factory keyless location, if i have it?
Old Nov 11, 2007 | 12:27 AM
Pheonixx's Avatar
i searched and found threads mostly for the 2004+ trucks. Im wondering if someone knows where the module would be for the keyless(if i have it). if i have it i would like to use it. also i have seen some threads about doing a keypad on a 99 door handle. again how do i find it to see if i have the box for it. if i have the box im betting i have the connector just above the drivers door speaker.
thanks
Old Nov 11, 2007 | 01:00 AM
SSCULLY's Avatar
Easy way, try the programming for adding RKE fobs :
Don't be disappointed if it does not work the 1st time. When I added an RKE fob to my 2001, it took me 3 times to enter programming mode. Really need to haul through the programming steps.
Good luck
Old Nov 11, 2007 | 08:18 AM
Pheonixx's Avatar
thanks for the reply, however since i did not get a fob when i bought the truck im unsure if i even have keyless. So i would like to know where to find the box to make sure i actually have keyless rather than depending on the locks to jump because unless i do that a zillion times i will never know i got it right. The truck is a 99 XLT flareside. power windows, locks etc (no power seats though).
Old Nov 12, 2007 | 11:05 PM
clearnoise's Avatar
Hm....a quick run out to my truck shows that mine is behind the fuse panel. It's kind of hard to read but the Ford sticker says "Remote Keyless Entry". I hope this is what you're looking for and that it helps.
