Interior Lights
Old Nov 5, 2007 | 02:02 PM
Big Guns's Avatar
Interior Lights
I couldn't find any posts on this, so here goes. The lights on some of my power window and door lock buttons have gone out. Also the light that shows the tranny position (P,R,D,3,2,1). Does anyone know where I can find a "how to" to replace these? I wonder if they are actually bulbs or LED's or what? My manual doesn't cover this. Any help?
_________________
04 F150 4x4 Screw Lariat 5.4L Triton, K&N 77 Series, Pro Comp 6" Susp Lift, Flow Master Dual Exhaust, Billet Grill (upper & lower).Edge Evo. Nitto Terragrapplers 325/60/18 on MB Blitz 18x10 Wheels. R1 Concepts cross drilled and slotted rotors. Troyer Preformance e-fans and underdrive pulleys.
Old Nov 5, 2007 | 02:57 PM
150 flareside's Avatar
_________________
need the same help here.
Old Nov 5, 2007 | 03:02 PM
yall shoot me an email i can pull your info up. Is the 04 a NBS?
Old Nov 6, 2007 | 01:02 AM
blacklariatfx4's Avatar
+1 for any additional info. The lights went out in both of the switches for my front windows. I'll be pulling the panel tomorrow to see if they have a separte/replaceable bulb or I'll have to swap switches.
Old Nov 6, 2007 | 01:08 AM
black you can email me too, just be specific in your email about what information you need
Old Nov 6, 2007 | 03:50 PM
Big Guns's Avatar
Pulled mine (very easy to do). Called Ford. They are a 'unit' containing the switchs and lights. You have to replace the entire switch. The drivers front side is $76, the front passenger is $56.
To pull the switch all you need to do is use a flat blade (like a butter knife or spakle tool) and pop apart the top of the armrest from the bottum of the arm rest right at the seam. Then unhook the wires. The 'unit box' will pop out after pressing in the tabs.
Mine is an 04 F150 Screw, NBS
