12v plug not working
Old Oct 25, 2007 | 08:43 PM
fordfarm's Avatar
search didn't give me any real results. my 12v accessory plug on the dash quit working....any suggestion. i'm still under warranty for 7 more weeks but would rather try this little deal myself. 2004 f-150
Old Oct 25, 2007 | 09:32 PM
travpeterson's Avatar
PDB under hood
Mine was not working when I bought my truck used. (2002 F150 XLT) There is a fuse for it under the hood in the Power Distribution Box. Fuse position #1 I believe it is a Yellow 20A. It should be the same from year to year I think and I hope that helps, Travis
Old Oct 25, 2007 | 09:54 PM
My apologies
I just checked the fuse panel on a 2004 and it is Fuse position #39, not #1 like I said before. I am sorry for any confusion. But I hope that helps more. Travis
Old Oct 26, 2007 | 08:07 AM
projectSHO89's Avatar
The owner's manual has the fuse panel layout in it.
If your original is missing, download a replacement from www.fleet.ford.com under MAINTENANCE.
Steve
Old Oct 27, 2007 | 09:31 AM
fordfarm's Avatar
thanks guys i'll check that out today
Old Oct 30, 2007 | 02:38 AM
joezasada's Avatar
probably a fuse. your OBD2 port's power will probably share that fuse, as in earlier models. if your run any high-drain devices (electric coolers!) on your accessory plug you may wish to add a circuit for those devices as 20A is only good for one or two devices.
Old Nov 5, 2007 | 09:55 AM
Titans Fan 527's Avatar
Different Circuit?
So are the cigarette lighter and the power point on different circuits? I have a 2000 F-150, and they are side by side. Mine quit working also. I heard a pop, so I checked the fuses. The one under the dash was shot. I replaced it, and the cigarette lighter started working. The one right next to it doesn't work now.
Old Nov 5, 2007 | 11:43 AM
eROKv's Avatar
yes the 2 power plugs are on different circuits. if i remember right, one of them has a fuse in the box under the hood and the other is under the dash on the drivers side.
Old Nov 6, 2007 | 10:57 AM
Thanks!
Cool, thanks! I'll check the one under the hood....
