Soft start set up for e-fans?
My lights dim briefly when my e-fans come on at night. Has anyone had this problem and how did you fix it? I remember reading something somewhere about a soft start up set-up? Can anyone give me advice?
Thanks in advance!
Thanks in advance!
i might want to check and see where you grabbed power from, the dimming is just the high current surge it takes to start the fans up. if you arent using a thick enough wire from a good power source, that could be why your lights dim.
Steve
Note's A good ground is not the metal frame of vehicle use copper all the way to battery the power wire should be straight to battery with a relay opening circuit relay controlled by run circuit from vehicle and thermostat and A/C if needed.
