Windows not rolling up or down
Old Oct 12, 2007 | 01:57 PM
99blue150's Avatar
Angry Windows not rolling up or down
I rolled down my passenger side window this morning and then tried to roll it up when i stopped and it wouldn't. I can't roll down my drivers side window either Is there a fuse that controls this and if so which one is it? It has been working fine and all of a sudden just stopped. I tried to roll it up with the passenger side switch and it doesnt work either any ideas what it could be please give me a suggestion.
Old Oct 14, 2007 | 09:08 AM
Ryan1979's Avatar
Power Windows not working?
Hello,
I had a simular problem but it was with the passanger side only. Turns out it was the switch on the drivers side. Are any fuses blown? Is there power at the switches or motors? Use a volt meter to trace back the problem. Start at the switches and you may have to get someone to push the swithes for you as you trouble shoot. Good Luck!
Cheers!
Old Oct 14, 2007 | 07:26 PM
4wd150's Avatar
my passenger window stopped working and i replaced the drivers side switches and it works
