KC off road lights won't work?
Old Sep 30, 2007 | 12:03 AM
Shootermay's Avatar
I have 2 older KC lights and can't get them to work. It doesnt appear that the bulbs are burnt out but there isnt a "bulb" it 2 prongs and a spring. can i change these or how do i get them to work? thanks
Old Sep 30, 2007 | 01:31 AM
fmf300ex's Avatar
Have you checked the fuses?
I know the wiring kit that came with my 6x9s has a fuse for the switch and one for the lights themselves. With either one blown the lights won't work.
I would imagine there is a fault in the wiring somewhere if both of them won't work. Check for shorts too if you've got a blown fuse. I know I accidentally tightened one of the lights on top of the power wire, causing it to become kinda crimped and expose a tiny bit of wire, so it would just short out and blow the fuse if I tried to turn them on. Fixed that, replaced the fuse, and they work great now.
Or could be the bulbs I guess.
Old Sep 30, 2007 | 12:56 PM
Shootermay's Avatar
well they aren't wired to anything and aren't wired to eachother. i have about 8 inches of pos and neg wire no fuse just direct and i tried to check them on my battery but they dont work there isnt really a bulb just 2 posts and a coil any ideas?
