2001 expedition side mirror turn signal
Old Sep 22, 2007 | 12:30 PM
cinderdick's Avatar
I need to find out if you can replace the turn signal bulb in the mirror. I t is the type with a tear drop signal mounted on the mirror base. How do you get to it if replaceable. And what is the bulb part number. The mirrors are memory, heated.
Old Sep 22, 2007 | 02:15 PM
Steve83's Avatar
Look in the back of the owner's or maintenance guide. There's USUALLY a list of every bulb application & number. If that application isn't listed, it's not replaceable separately from the mirror.
Old Sep 23, 2007 | 11:03 AM
SSCULLY's Avatar
Search on the term signal mirror bulb produces 14 threads.
Good one with the step by step from Joe on glamor cap removal :
https://www.f150online.com/forums/sh...al+mirror+bulb
One that I post 3 threads ( prior to Joe's ) with directions and the bulb part numbers :
The 2001 F-150 owners manual lists the signal mirror bulb as a 906/921 on page 188, your Expedition might be different, so check your owner's manual in the Maintenance and Care section.
