98 F150 Speedometer will go upto 40 mph
Old Sep 16, 2007 | 08:29 PM
triplehellcat's Avatar
98 F150 Speedometer will go upto 40 mph and stop (stays at 38 to 40 mph). No matter how fast or slow I go. The only way to get it to return to 0 mph is to stop and turn the key off. I did install a new speed sensor that mounts on the tailshaft of the trans. Still the same problem exists.
Old Sep 16, 2007 | 08:42 PM
Get in the truck, push the odo reset button, and turn the key to start the truck, keep on holding it. It should go through a cluster test, sweeping the gauges and all dummy lights should light up.
Your speedometer should go from 0-100 with this test. IF it gets hung up at 38-40 mph, you need a new gauge cluster.
If you do, it will run you a pretty penny... like $400 plus the odo recaliberation.
Old Sep 16, 2007 | 09:53 PM
torkum's Avatar
Contact these people, they don't have a web site that I can find: Southern Autotronics / 10625 Trade Rd. / Richmond, VA 804-379-5601
Old Sep 17, 2007 | 05:53 AM
This is a analog cluster. Will this test work on this type?
Thanks.....Chris
