High Beams Wont Click On
Old Sep 15, 2007 | 05:56 AM
djmur's Avatar
The high beams come on only if I hold the mfs towards me. They wont click on. Any suggestions other than replacing the mfs?
Old Sep 15, 2007 | 07:39 AM
torkum's Avatar
Might try cleaning the mfs. The grease Ford uses sometimes gets hard and cracks causing contact problems.
Old Sep 16, 2007 | 10:42 AM
SSCULLY's Avatar
When you use the FTP ( flash to Pass or towards you ) the high beams work.
When you push the MFS forward what happens ?
- MFS clicks forward, but high beams don't light
- MFS stays forward, or returns to low beam position
- MFS does not click forward, but high beams light
- any thing else, these are just items I can think might happen.
FTP uses a separate part of the MFS circuit, so if it clicks forward, and does not work, could be a Main headlamp switch problem, or a MFS problem ( long the lines of torkum's post )
Old Sep 16, 2007 | 02:09 PM
Steve83's Avatar
Test the MFS.
Old Sep 17, 2007 | 01:31 PM
djmur's Avatar
I'm an idiot
I just bought the truck and I assumed that you pulled the MFS toward you to turn the high beams on.....I took your suggestion and pushed the lever...The high beams came on....
duh
Old Sep 17, 2007 | 01:35 PM
luke280's Avatar
