Bulb in AC Controls
Old Aug 30, 2007 | 11:55 PM
MattDickson's Avatar
Bulb in AC Controls
my bulb in my ac controls went out...how do u replace it and what bulb do i need...thanks for yalls help...
Old Aug 31, 2007 | 09:39 AM
Larry227's Avatar
Not sure about the 2003 but in my 2000 you just pop off the trim around the radio/heater controls then take out four screws that hold the heater control in. Pull out the switch cluster and remove the bulb from the back. I think mine uses the small push in 194 bulb, it's been awhile since I changed it.
Old Aug 31, 2007 | 10:49 PM
whats the best way to pull the trim off...?
Old Aug 31, 2007 | 11:34 PM
Larry227's Avatar
I usually take a small thin knife blade and work it behind the right upper corner and pop that out then work my fingers around it while pulling out the rest. Mine has 5 push-in connectors, yours may have more. Here's what mine looks like pulled out.
https://www.f150online.com/galleries...354&anum=14615
https://www.f150online.com/galleries...353&anum=14615
