horn problem
Old Aug 25, 2007 | 01:50 PM
bad2wd's Avatar
horn problem
well horn stopped working so I went and bought a new horn installed it, nothing checked the wires all look good still nothing, replaced the horn relay and still nothing. any other ideas? 200 F150 and worked before last week now.... dead as dead can be.
is there a contact in the steering wheel and if there is how to check it out?
Old Aug 25, 2007 | 09:48 PM
projectSHO89's Avatar
Does your cruise work and/or do you have an airbag fault lamp?
Steve
Old Aug 25, 2007 | 09:50 PM
bad2wd's Avatar
Horn Not Working
AS A MATTER OF FACT i NOTICED THE CRUISE IS NOT WORKIKNG LAST WEEK BUT i HAVE NOT SEEN AN AIR BAG LIGHT COME ON? ARE THESE CONNECTED SOMEHOW?
Old Aug 26, 2007 | 01:16 AM
Steve83's Avatar
Click the tan CV below & look in the Steering Column album. Sounds like your clock spring is starting to crack.
Old Aug 26, 2007 | 08:36 AM
The cruise switches, horn, and airbag circuits all share parts of the clockspring. If all three functions are affected, it's very definitive that the clockspring is at issue. With only two functions affected, it's still a good possibility, just not as clearly defined.
Steve
Old Aug 26, 2007 | 10:11 AM
bad2wd's Avatar
I looked at the 26 pics and....
whic is the clock spring? I even looked at the exploded one but I could not figure out which one of the 80+ it was. sorry to be such trouble. About hiw long will it take to fix or should I take it to a shop?
Old Aug 26, 2007 | 01:21 PM
Steve83's Avatar
When you were looking at those 80+ parts, did you notice that they're numbered? Did you scroll down to the caption & see the list of numbers followed by names & Ford PNs? Maybe just as far as "7 Air Bag Sliding Contact (Clock Spring) 14A664"? Or the next 2 photos which have "Clock Spring" in their filenames?
