Fuel Pump Relay Location
I have a 95 F150 5.0 and am wanting to replace the fuel pump relay. I know the relay/fuse box is under the hood on the drivers side. It says on the box to refer to the owners manual to identify the relays. I don't have the manual. There are five identical relays on the right side of the box. Anyone know which one is for the fuel pump? This would be easier if the relay was always bad. Then I could swap until the fuel pump kicked on. I think it's intermittant and a cheap attempt to fix this problem. Thanks
Originally Posted by projectSHO89
Thanks for the info, saved it under my service manual directory on the server
